scsiblade.vs events
Creating your file...
Your file is ready
scsiblade.vs.purge.fail
- Severity
EMERGENCY
- Description
This message occurs when the local node fails to purge the SAN configuration cache for a Vserver. Manual intervention is required to allow reinitialization of the specified Vserver.
- Corrective Action
Reboot the node, and if the node is waiting for giveback, perform a giveback operation.
- Syslog Message
The local node failed to purge the SAN configuration cache for Vserver %s.
- Parameters
vserver (STRING): Name or UUID of the Vserver.
