ONTAP EMS reference
scsiblade.vs events
scsiblade.vs.purge.fail
Severity
EMERGENCY
This message occurs when the local node fails to purge the SAN configuration cache for a Vserver. Manual intervention is required to allow reinitialization of the specified Vserver.
Corrective Action
Reboot the node, and if the node is waiting for giveback, perform a giveback operation.
Syslog Message
The local node failed to purge the SAN configuration cache for Vserver %s.
vserver (STRING): Name or UUID of the Vserver.
