The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
spider.message events
Creating your file...
Your file is ready
spider.message.fail
- Severity
ALERT
- Description
This message occurs when a directory traversal task cannot finish because of an unexpected error.
- Corrective Action
Ensure all nodes in the cluster are online and healthy, and that all volumes needed for the directory traversal are online. Then retry the operation.
- Syslog Message
Volume %llu failed to perform directory task %s because of %s.
- Parameters
volume_dsid (LONGINT): DSID of the volume that encountered the error.
task (STRING): Description of the task that could not be performed.
error (STRING): Description of the error that occurred.
