spider.message events
spider.message.fail
- Severity
ERROR
- Description
This message occurs when a directory traversal task cannot finish because of an unexpected error.
- Corrective Action
Ensure all nodes in the cluster are online and healthy, and that all volumes needed for the directory traversal are online. Then retry the operation.
- Syslog Message
Volume %llu failed to perform directory task %s because of %s.
- Parameters
volume_dsid (LONGINT): DSID of the volume that encountered the error.
task (STRING): Description of the task that could not be performed.
error (STRING): Description of the error that occurred.
