ONTAP EMS reference
spider.message events
spider.message EMS events occur when a directory traversal task cannot finish because of an unexpected error.
spider.message.fail
Severity
ERROR
This message occurs when a directory traversal task cannot finish because of an unexpected error.
Corrective Action
Ensure all nodes in the cluster are online and healthy, and that all volumes needed for the directory traversal are online. Then retry the operation.
Syslog Message
Volume %llu failed to perform directory task %s because of %s.
volume_dsid (LONGINT): DSID of the volume that encountered the error.
task (STRING): Description of the task that could not be performed.
error (STRING): Description of the error that occurred.
