      nvram.hw events
nvram.hw.degraded
- Severity
ERROR
 - Description
This message occurs when the NVRAM hardware is degraded.
 - Corrective Action
Contact NetApp technical support for replacement assistance.
 - Syslog Message
NVRAM hardware is degraded: %s.
 - Parameters
reasonText (STRING): Reason the NVRAM hardware is degraded.
nvram.hw.initFail
- Severity
EMERGENCY
 - Description
This message occurs when the Data ONTAP® NVRAM hardware fails to initialize.
 - Corrective Action
Typically, this type of error is unexpected and indicates that the NVRAM hardware is failing and should be replaced. Contact NetApp technical support for assistance with the replacement.
 - Syslog Message
NVRAM hardware initialization failed: %s.
 - Parameters
error (STRING): Description of the error.
nvram.hw.normal
- Severity
NOTICE
 - Description
This message occurs when the NVRAM hardware is operating normally.
 - Corrective Action
(None).
 - Syslog Message
 - Parameters
(None).
