nvram.hw events
Creating your file...
Your file is ready
nvram.hw.degraded
- Severity
ERROR
- Description
This message occurs when the NVRAM hardware is degraded.
- Corrective Action
Contact NetApp technical support for replacement assistance.
- Syslog Message
NVRAM hardware is degraded: %s.
- Parameters
reasonText (STRING): Reason the NVRAM hardware is degraded.
nvram.hw.initFail
- Severity
EMERGENCY
- Description
This message occurs when the Data ONTAP® NVRAM hardware fails to initialize.
- Corrective Action
Typically, this type of error is unexpected and indicates that the NVRAM hardware is failing and should be replaced. Contact NetApp technical support for assistance with the replacement.
- Syslog Message
NVRAM hardware initialization failed: %s.
- Parameters
error (STRING): Description of the error.
nvram.hw.normal
- Severity
NOTICE
- Description
This message occurs when the NVRAM hardware is operating normally.
- Corrective Action
(None).
- Syslog Message
- Parameters
(None).
