The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nvram.hw events
Creating your file...
Your file is ready
nvram.hw.degraded
- Severity
ERROR
- Description
This message occurs when the NVRAM hardware is degraded.
- Corrective Action
Contact NetApp technical support for replacement assistance.
- Syslog Message
NVRAM hardware is degraded: %s.
- Parameters
reasonText (STRING): Reason the NVRAM hardware is degraded.
nvram.hw.initFail
- Severity
EMERGENCY
- Description
This message occurs when the Data ONTAP® NVRAM hardware fails to initialize.
- Corrective Action
Typically, this type of error is unexpected and indicates that the NVRAM hardware is failing and should be replaced. Contact NetApp technical support for assistance with the replacement.
- Syslog Message
NVRAM hardware initialization failed: %s.
- Parameters
error (STRING): Description of the error.
nvram.hw.normal
- Severity
NOTICE
- Description
This message occurs when the NVRAM hardware is operating normally.
- Corrective Action
(None).
- Syslog Message
- Parameters
(None).
