nvram.hw events
nvram.hw.degraded
Severity
ERROR
This message occurs when the NVRAM hardware is degraded.
Corrective Action
Contact NetApp technical support for replacement assistance.
Syslog Message
NVRAM hardware is degraded: %s.
reasonText (STRING): Reason the NVRAM hardware is degraded.
nvram.hw.initFail
Severity
EMERGENCY
This message occurs when the Data ONTAP® NVRAM hardware fails to initialize.
Corrective Action
Typically, this type of error is unexpected and indicates that the NVRAM hardware is failing and should be replaced. Contact NetApp technical support for assistance with the replacement.
Syslog Message
NVRAM hardware initialization failed: %s.
error (STRING): Description of the error.
nvram.hw.normal
Severity
NOTICE
This message occurs when the NVRAM hardware is operating normally.
Corrective Action
(None).
Syslog Message
(None).
