monitor.weeklystatsasup events
Creating your file...
Your file is ready
monitor.weeklyStatsASUP.off
- Severity
ERROR
- Description
This message occurs when weekly performance AutoSupport(tm) is disabled.
- Corrective Action
Enable the weekly performance AutoSupport by entering the "options stats.autosupport.weekly.enable on" command. You must have the correct privilege to run this command.
- Syslog Message
Weekly performance AutoSupport has been disabled.
- Parameters
(None).
