      monitor.weeklystatsasup events
monitor.weeklyStatsASUP.off
- Severity
ERROR
 - Description
This message occurs when weekly performance AutoSupport(tm) is disabled.
 - Corrective Action
Enable the weekly performance AutoSupport by entering the "options stats.autosupport.weekly.enable on" command. You must have the correct privilege to run this command.
 - Syslog Message
Weekly performance AutoSupport has been disabled.
 - Parameters
(None).
