ONTAP EMS reference
monitor.weeklystatsasup events
monitor.weeklystatsasup EMS events occur when weekly performance AutoSupport(tm) is disabled.
monitor.weeklyStatsASUP.off
Severity
ERROR
This message occurs when weekly performance AutoSupport(tm) is disabled.
Corrective Action
Enable the weekly performance AutoSupport by entering the "options stats.autosupport.weekly.enable on" command. You must have the correct privilege to run this command.
Syslog Message
Weekly performance AutoSupport has been disabled.
(None).
