csm.homeportinfounexpected events
Creating your file...
csm.homePortInfoUnexpected
- Severity
NOTICE
- Description
This message occurs when the Cluster Session Manager (CSM) establishes a connection between nodes over the cluster network interface of a switchless cluster and detects that the logical interface's (LIF's) home port and the corresponding remote device information are not the expected values.
- Corrective Action
This message can occasionally happen during normal operations on a system startup or a LIF migration event. If the message repeats every few minutes, it might indicate a problem in the cluster interface configuration or the physical cabling of the switchless cluster.
- Syslog Message
CSM reports unexpected information for cluster LIF ID "%d" (home port: "%s", remote device ID: "%s").
- Parameters
vifId (INT): ID of the local cluster LIF over which the connection gets established.
homePort (STRING): Home port hosting the LIF.
remoteDeviceId (STRING): Remote device associated with the home port.
