      encryption.queue events
encryption.queue.op.failed
- Severity
ERROR
 - Description
This message occurs when an operation on the volume in the encryption queue failed.
 - Corrective Action
Check the reason for the failure included in the message. Correct the issue and try the operation again.
 - Syslog Message
%s operation failed on the queued volume '%s' in Vserver '%s'. Reason: %s.
 - Parameters
op (STRING): Conversion operation.
volumename (STRING): Name of the volume.
vservername (STRING): Name of the Vserver.
reason (STRING): Reason for the failure.
