ONTAP EMS reference
config.sas2domain events
config.SAS2Domain
Severity
ERROR
This message occurs when a disk is multipathed to one SAS domain; that is, both ports of the disk are visible from the same HBA port.
Corrective Action
Recable the disk shelf containing the specified disk, so that the two disk ports are in different SAS domains.
Syslog Message
Disk %s is multipathed to the same SAS domain. The two disk ports must be in different SAS domains.
disk (STRING): Name of the disk.
