config.sas2domain events
config.sas2domain EMS events occur when a disk is multipathed to one SAS domain; that is, both ports of the disk are visible from the same HBA port.
config.SAS2Domain
- Severity
ERROR
- Description
This message occurs when a disk is multipathed to one SAS domain; that is, both ports of the disk are visible from the same HBA port.
- Corrective Action
Recable the disk shelf containing the specified disk, so that the two disk ports are in different SAS domains.
- Syslog Message
Disk %s is multipathed to the same SAS domain. The two disk ports must be in different SAS domains.
- Parameters
disk (STRING): Name of the disk.
