usb.port events
Creating your file...
Your file is ready
usb.port.error
- Severity
ERROR
- Description
This message occurs when the Data ONTAP® universal serial bus (USB) adapter driver detects an unrecoverable error on the associated port.
- Corrective Action
If a device is attached to the associated port, try reinserting the device. If that fails, try replacing the device. If the problem persists, contact NetApp technical support for assistance in diagnosing a USB issue.
- Syslog Message
In adapter %s, unrecoverable error detected for port %d. Ignoring attached device.
- Parameters
adapterName (STRING): Name of the associated USB adapter.
port (INT): Associated port number.
