diskown.uprevversion events
Creating your file...
Your file is ready
diskown.UpRevVersion
- Severity
NOTICE
- Description
This message occurs when disk ownership information has been read and found to be from a version that is higher (newer) than what the current version of Data ONTAP understands. New fields in the ownership information will be ignored.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
diskname (STRING): The name of the disk with the newer version.
serialno (STRING): The serial number of the disk.
foundversion (INT): The version of the disk ownership information found on the disk.
curversion (INT): The version of the disk ownership information that the current Data ONTAP uses.
