ONTAP EMS reference
diskown.uprevversion events
diskown.uprevversion EMS events occur when disk ownership information has been read and found to be from a version that is higher (newer) than what the current version of Data ONTAP understands.
diskown.UpRevVersion
Severity
NOTICE
This message occurs when disk ownership information has been read and found to be from a version that is higher (newer) than what the current version of Data ONTAP understands. New fields in the ownership information will be ignored.
Corrective Action
(None).
Syslog Message
(None).
diskname (STRING): The name of the disk with the newer version.
serialno (STRING): The serial number of the disk.
foundversion (INT): The version of the disk ownership information found on the disk.
curversion (INT): The version of the disk ownership information that the current Data ONTAP uses.
