mcc.ipspace events
mcc.ipspace.not.found
Severity
ERROR
This message occurs when the IPspace is not found in a MetroCluster(tm) configuration while replicating the object store configuration. Until this is resolved, some MetroCluster and FabricPool operations will fail.
Corrective Action
Create the missing MetroCluster IPspace. The configuration replication task will be completed automatically.
Syslog Message
Object store "%s" configuration replication failed because IPspace "%s" was not found in cluster "%s".
object_store_name (STRING): Name of the object store.
ipspace_name (STRING): Name of the IPspace.
cluster_name (STRING): Name of the cluster.
