mcc.ipspace events
Creating your file...
Your file is ready
mcc.ipspace.not.found
- Severity
ERROR
- Description
This message occurs when the IPspace is not found in a MetroCluster(tm) configuration while replicating the object store configuration. Until this is resolved, some MetroCluster and FabricPool operations will fail.
- Corrective Action
Create the missing MetroCluster IPspace. The configuration replication task will be completed automatically.
- Syslog Message
Object store "%s" configuration replication failed because IPspace "%s" was not found in cluster "%s".
- Parameters
object_store_name (STRING): Name of the object store.
ipspace_name (STRING): Name of the IPspace.
cluster_name (STRING): Name of the cluster.
