nblade.vscanbadipprivaccess events
nblade.vscanbadipprivaccess EMS events occur during a client attempt to connect to the privileged ONTAP_ADMIN$ share, when the IP address of that client is not found in the list of allowed IP addresses.
Nblade.vscanBadIPPrivAccess
- Severity
ERROR
- Description
This message occurs during a client attempt to connect to the privileged ONTAP_ADMIN$ share, when the IP address of that client is not found in the list of allowed IP addresses.
- Corrective Action
Ensure that the mentioned IP address is configured in one of the active vscan scanner pools. Use the "vserver vscan scanner pool show-active" command to view the currently active scanner pool configuration.
- Syslog Message
For Vserver "%s", the attempt to connect to the privileged ONTAP_ADMIN$ share by the client "%s" is rejected because its IP or hostname is not configured in any of the Vserver active scanner pools.
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the client.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
