The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.fpolpsvolnotfound events
Creating your file...
Your file is ready
Nblade.fpolPsVolNotFound
- Severity
ERROR
- Description
This message occurs when volume corresponding to persistent store is not found. This causes disruption in FPolicy where persistent store is enabled.
- Corrective Action
Check the volume corresponding to the persistent store. Either recreate the volume with same name or delete the persistent store.
- Syslog Message
FPolicy persistent store volume "%s" belonging to SVM "%s" was not found.
- Parameters
volName (STRING): Persistent store volume.
vserverName (STRING): Name of the SVM.
