nblade.fpolpsvolnotfound events
Nblade.fpolPsVolNotFound
- Severity
ERROR
- Description
This message occurs when volume corresponding to persistent store is not found. This causes disruption in FPolicy where persistent store is enabled.
- Corrective Action
Check the volume corresponding to the persistent store. Either recreate the volume with same name or delete the persistent store.
- Syslog Message
FPolicy persistent store volume "%s" belonging to SVM "%s" was not found.
- Parameters
volName (STRING): Persistent store volume.
vserverName (STRING): Name of the SVM.
