ONTAP EMS reference
acp.exp events
acp.exp.power.cycle
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor receives a command to power-cycle the SAS expander.
Corrective Action
(None).
Syslog Message
SAS expander power-cycle request sent to %s (%s), (disk shelf serial number: %s).
inband_id (STRING): In-band ID of the module.
ip (STRING): IP address of the module.
status (STRING): Status code returned by the 'expander power cycle' command.
acp.exp.power.cycle.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Controller Path Administrator fails in its attempt to power-cycle the SAS expander.
Corrective Action
(None).
Syslog Message
SAS expander power-cycle request sent to %s (%s) failed with status (%s), (disk shelf serial number: %s).
status (STRING): Reason for the 'expander power-cycle' failure.
shelf_sno (STRING): Shelf serial number of the shelf where this I/O module is seated.
acp.exp.power.cycle.success
Severity
INFORMATIONAL
This message occurs when an 'expander power cycle' command sent to the Alternate Controller Path (ACP) Processor succeeds.
Corrective Action
(None).
Syslog Message
SAS expander power cycle command sent to %s (%s) was successful, (disk shelf serial number: %s).
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
acp.exp.reset
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor receives a command to reset a SAS expander.
Corrective Action
(None).
Syslog Message
SAS expander reset issued to %s (%s), (disk shelf serial number: %s).
status (STRING): Status code returned by the 'expander reset' command.
acp.exp.reset.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Controller Path Administrator fails in its attempt to reset the SAS expander.
Corrective Action
(None).
Syslog Message
SAS expander reset request sent to %s (%s) failed with status (%s), (disk shelf serial number: %s).
status (STRING): Reason for the 'expander reset' failure.
acp.exp.reset.success
Severity
INFORMATIONAL
This message occurs when an 'expander reset' command sent to the Alternate Controller Path (ACP) Processor succeeds.
Corrective Action
(None).
Syslog Message
SAS expander reset command sent to %s (%s) was successful, (disk shelf serial number: %s).
acp.exp.vpd.failed
Severity
INFORMATIONAL
This message occurs when an attempt to get SAS expander VPD (Vital Product Data) data from the Alternate Control Path Processor fails.
Corrective Action
(None).
Syslog Message
An 'expander vpd' request sent to %s (%s) failed with status (%s), (disk shelf serial number: %s).
status (STRING): Reason for the failure to get the SAS expander vpd data.
