flexcache.featuredisabled events
Creating your file...
Your file is ready
flexcache.featureDisabled
- Severity
ERROR
- Description
This message occurs when an attempt is made to mount a FlexCache volume. FlexCache is no longer supported, please remove any remaining FlexCache volumes left over from upgrading the cluster.
- Corrective Action
Delete all FlexCache volumes in the cluster. They can be displayed by using the "volume flexcache show" command.
- Syslog Message
(None).
- Parameters
volume (STRING): FlexCache volume involved.
