ONTAP EMS reference
flexcache.featuredisabled events
flexcache.featureDisabled
Severity
ERROR
This message occurs when an attempt is made to mount a FlexCache volume. FlexCache is no longer supported, please remove any remaining FlexCache volumes left over from upgrading the cluster.
Corrective Action
Delete all FlexCache volumes in the cluster. They can be displayed by using the "volume flexcache show" command.
Syslog Message
(None).
volume (STRING): FlexCache volume involved.
