The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
flexcache.featuredisabled events
Creating your file...
Your file is ready
flexcache.featureDisabled
- Severity
ERROR
- Description
This message occurs when an attempt is made to mount a FlexCache volume. FlexCache is no longer supported, please remove any remaining FlexCache volumes left over from upgrading the cluster.
- Corrective Action
Delete all FlexCache volumes in the cluster. They can be displayed by using the "volume flexcache show" command.
- Syslog Message
(None).
- Parameters
volume (STRING): FlexCache volume involved.
