ONTAP EMS reference
wafl.qtree events
wafl.qtree.id.mismatch
Severity
ERROR
This message occurs when a qtree ID derived from a WAFL® buffer does not match the given tree ID in a Snapshot(tm) copy.
Corrective Action
Delete the Snapshot copy containing the qtree for non SnapMirror® DP volumes. For SnapMirror DP volumes, run wafliron with the "-include-mirrors" option set to true to fix the entry. For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
Syslog Message
Qtree ID %d is recorded as ID %d in %s %s%s%s%s in Snapshot copy %d.
tid (INT): Source tree identifier.
id (INT): Qtree root identifier.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
snapId (INT): Snapshot copy identifier.
wafl.qtree.invalid.state
Severity
ERROR
This message occurs when the qtree file in a Snapshot(tm) copy is in an invalid state.
Corrective Action
Delete the Snapshot copy containing the qtree for non SnapMirror® DP volumes. For SnapMirror DP volumes, run wafliron with the "-include-mirrors" option set to true to fix the entry.For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
Syslog Message
Qtree file in %s %s%s%s%s is in an invalid state %d in Snapshot copy %d.
volident (STRING): Unique identifier for the volume in cases in which the volume name alone is insufficient.
reason (INT): State of the qtree file.
wafl.qtree.metafile.corrupt
Severity
ERROR
This message occurs when the qtree metafile in a Snapshot(tm) copy is inconsistent.
Corrective Action
Run wafliron to fix the inconsistent volume. Use the "-include-mirrors" option if the volume is a SnapMirror® DP volume. For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
Syslog Message
Qtree metafile inconsistent in volume %s%s%s, Snapshot copy %d.
wafl.qtree.qsmBreak.base
Severity
ERROR
This message occurs when the SnapMirror® information of the qtree is being removed as result of WAFL_check operation.
Corrective Action
Use the "snapmirror resync" or "snapmirror initialize" to reestablish the SnapMirror relationship.
Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: base Snapshot(tm) copy no longer exists. Use the "snapmirror resync" or "snapmirror initialize" to reestablish the SnapMirror relationship.
qtree (INT): Qtree identifier.
wafl.qtree.qsmBreak.iron
Severity
ERROR
This message occurs when the SnapMirror® information of the qtree is being removed as result of a wafliron operation.
Corrective Action
Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: wafliron broke all SnapMirror relationships in %s %s%s%s%s. Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
volident1 (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
type2 (STRING): Type of object (volume or aggregate).
owner2 (STRING): Volume owner.
vol2 (STRING): Volume name.
app2 (STRING): Application UUID.
volident2 (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.qtree.qsmBreak.wc
Severity
ERROR
This message occurs when snapmirror information of the qtree is being removed as result of wack
Corrective Action
Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: WAFL_check broke all SnapMirror relationships in %s %s%s%s%s. Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
volident1 (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
volident2 (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
