wafl.qtree events
wafl.qtree EMS events occur when ONTAP encounters issues associated with qtree metadata and SnapMirror relationships.
wafl.qtree.id.mismatch
- Severity
ERROR
- Description
This message occurs when a qtree ID derived from a WAFL® buffer does not match the given tree ID in a snapshot.
- Corrective Action
Delete the snapshot containing the qtree for non SnapMirror® DP volumes. For SnapMirror DP volumes, run wafliron with the "-include-mirrors" option set to true to fix the entry. For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
- Syslog Message
Qtree ID %d is recorded as ID %d in %s %s%s%s%s in snapshot %d.
- Parameters
tid (INT): Source tree identifier.
id (INT): Qtree root identifier.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
snapId (INT): Snapshot identifier.
wafl.qtree.invalid.state
- Severity
ERROR
- Description
This message occurs when the qtree file in a snapshot is in an invalid state.
- Corrective Action
Delete the snapshot containing the qtree for non SnapMirror® DP volumes. For SnapMirror DP volumes, run wafliron with the "-include-mirrors" option set to true to fix the entry.For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
- Syslog Message
Qtree file in %s %s%s%s%s is in an invalid state %d in snapshot %d.
- Parameters
volident (STRING): Unique identifier for the volume in cases in which the volume name alone is insufficient.
reason (INT): State of the qtree file.
wafl.qtree.metafile.corrupt
- Severity
ERROR
- Description
This message occurs when the qtree metafile in a snapshot is inconsistent.
- Corrective Action
Run wafliron to fix the inconsistent volume. Use the "-include-mirrors" option if the volume is a SnapMirror® DP volume. For example, run the "wafliron start -aggr aggr_name -include-mirrors true" command, where aggr_name is the aggregate for the given volume.
- Syslog Message
Qtree metafile inconsistent in volume %s%s%s, snapshot %d.
- Parameters
wafl.qtree.qsmBreak.base
- Severity
ERROR
- Description
This message occurs when the SnapMirror® information of the qtree is being removed as result of WAFL_check operation.
- Corrective Action
Use the "snapmirror resync" or "snapmirror initialize" to reestablish the SnapMirror relationship.
- Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: base snapshot no longer exists. Use the "snapmirror resync" or "snapmirror initialize" to reestablish the SnapMirror relationship.
- Parameters
qtree (INT): Qtree identifier.
wafl.qtree.qsmBreak.iron
- Severity
ERROR
- Description
This message occurs when the SnapMirror® information of the qtree is being removed as result of a wafliron operation.
- Corrective Action
Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
- Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: wafliron broke all SnapMirror relationships in %s %s%s%s%s. Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
- Parameters
volident1 (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
type2 (STRING): Type of object (volume or aggregate).
owner2 (STRING): Volume owner.
vol2 (STRING): Volume name.
app2 (STRING): Application UUID.
volident2 (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.qtree.qsmBreak.wc
- Severity
ERROR
- Description
This message occurs when snapmirror information of the qtree is being removed as result of wack
- Corrective Action
- Syslog Message
Breaking SnapMirror qtree %d in %s %s%s%s%s: WAFL_check broke all SnapMirror relationships in %s %s%s%s%s. Use the "snapmirror resync" or "snapmirror initialize" command to reestablish the SnapMirror relationship.
- Parameters
volident1 (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
volident2 (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
