The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmt.cifsserver events
Creating your file...
Your file is ready
mgmt.cifsserver.failure
- Severity
ERROR
- Description
This message occurs when a CIFS server fails to be configured and, therefore, CIFS access might not be available.
- Corrective Action
Check the reason for the error and take action accordingly. For further assistance, contact techinal support.
- Syslog Message
Failed to configure CIFS server. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
cifsservername (STRING): Name of the cifs server.
mgmt.cifsserver.success
- Severity
INFORMATIONAL
- Description
This message occurs when a CIFS server is successfully configured after a failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
