ONTAP EMS reference
mgmt.cifsserver events
mgmt.cifsserver EMS events occur when ONTAP encounters issues associated with CIFS server configuration.
mgmt.cifsserver.failure
Severity
ERROR
This message occurs when a CIFS server fails to be configured and, therefore, CIFS access might not be available.
Corrective Action
Check the reason for the error and take action accordingly. For further assistance, contact technical support.
Syslog Message
Failed to configure CIFS server. Error: %s.
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
cifsservername (STRING): Name of the cifs server.
mgmt.cifsserver.success
Severity
INFORMATIONAL
This message occurs when a CIFS server is successfully configured after a failure.
Corrective Action
(None).
Syslog Message
(None).
