The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage.cmd events
Creating your file...
Your file is ready
storage.cmd.balanceRequest
- Severity
INFORMATIONAL
- Description
Indicates a user request to balance I/O across initiator ports has been issued.
- Corrective Action
(None).
- Syslog Message
Storage related I/O has been balanced across available initiator ports.
- Parameters
(None).
storage.cmd.logPortIO
- Severity
INFORMATIONAL
- Description
Logs the mix of I/O bound to a specific initiator port prior to balancing. Issued for all initiator ports when a user requests a balancing of I/O.
- Corrective Action
(None).
- Syslog Message
Initiator Port %s had %d percent of all storage bound I/O traffic routed through it.
- Parameters
portName (STRING): The name of the initiator port
ioPct (INT): The percentage of overall backend I/O routed through this port
