The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snapmirror.multipath events
Creating your file...
Your file is ready
snapmirror.multipath.initErr
- Severity
ERROR
- Description
This event is issued during boot or during takeover when the filer is unable to setup the necessary infrastructure required for SnapMirror multipathing support.
- Corrective Action
Check the network connectivity on the source and the destination side. If the problem persists then, contact NetApp technical support
- Syslog Message
SnapMirror is unable to setup multipath connection support on %s host.
- Parameters
host (STRING): The host, local or partner
