snapmirror.multipath events
Creating your file...
Your file is ready
snapmirror.multipath.initErr
- Severity
ERROR
- Description
This event is issued during boot or during takeover when the filer is unable to setup the necessary infrastructure required for SnapMirror multipathing support.
- Corrective Action
Check the network connectivity on the source and the destination side. If the problem persists then, contact NetApp technical support
- Syslog Message
SnapMirror is unable to setup multipath connection support on %s host.
- Parameters
host (STRING): The host, local or partner
