ONTAP EMS reference
snapmirror.multipath events
snapmirror.multipath.initErr
Severity
ERROR
This event is issued during boot or during takeover when the filer is unable to setup the necessary infrastructure required for SnapMirror multipathing support.
Corrective Action
Check the network connectivity on the source and the destination side. If the problem persists then, contact NetApp technical support
Syslog Message
SnapMirror is unable to setup multipath connection support on %s host.
host (STRING): The host, local or partner
