wafl.relocating events
wafl.relocating EMS events occur when ONTAP encounters issues associated with aggregate relocation operation restrictions.
wafl.relocating.fence.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform an aggregate relocation because a fence is set on one of the volumes in the aggregate. The relocation is aborted.
- Corrective Action
A volume in the aggregate is currently fenced for group operations. Retry aggregate relocation after any group SnapRestore® or mirror transfers are complete. If the problem persists, contact technical support.
- Syslog Message
%s %s%s%s%s has a fence set. Canceling aggregate relocation.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Unique volume identity when the volume name itself is insufficient.
wafl.relocating.iron.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform an aggregate relocation because wafliron is active. The relocation is aborted.
- Corrective Action
Retry aggregate relocation after wafliron is finished.
- Syslog Message
%s %s%s%s%s is running vol wafliron. Canceling aggregate relocation.
- Parameters
wafl.relocating.sp.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform an aggregate relocation because a secure purge operation is in progress on one of the volumes in the aggregate. The relocation is aborted.
- Corrective Action
A volume in the aggregate is currently going through a secure purge operation. Retry aggregate relocation after this operation is complete, or after you abort the operation by using the "volume encryption secure-purge abort" command. If the problem persists, contact NetApp technical support.
- Syslog Message
A secure purge operation is in progress on %s %s%s%s. Canceling aggregate relocation.
- Parameters
