ONTAP EMS reference
cluster.port events
cluster.port EMS events occur when the cluster ports are operating at an unsupported speed.
cluster.port.unsupport.speed
Severity
ERROR
This message occurs when the cluster ports are operating at an unsupported speed.
Corrective Action
Ensure that the cluster port has a supported network interface card installed, and that it is operating at the supported speed.
Syslog Message
%s node %s cluster ports are not operating at a supported speed. Ensure that ports %s have supported network interface card installed, and are operating at a supported speed: %s.
model_name (STRING): Model on which the misconfigured ports reside.
node (STRING): Node on which the misconfigured ports reside.
portlist (STRING): List of misconfigured ports.
supported_speed (STRING): Speed at which the port is supported.
