ONTAP EMS reference
cluster.port events
cluster.port.unsupport.speed
Severity
ERROR
This message occurs when the cluster ports are operating at an unsupported speed.
Corrective Action
Ensure that the cluster port has a supported network interface card installed, and that it is operating at the supported speed.
Syslog Message
%s node %s cluster ports are not operating at a supported speed. Ensure that ports %s have supported network interface card installed, and are operating at a supported speed: %s.
model_name (STRING): Model on which the misconfigured ports reside.
node (STRING): Node on which the misconfigured ports reside.
portlist (STRING): List of misconfigured ports.
supported_speed (STRING): Speed at which the port is supported.
