disk.fw events
disk.fw EMS events occur when ONTAP encounters issues associated with disk firmware versions.
disk.fw.autodownrev
- Severity
INFORMATIONAL
- Description
This message occurs when the system detects disks with firmware that is not up-to-date. The background firmware update program will update the firmware automatically if the correct firmware files are in place.
- Corrective Action
Download the correct firmware file onto the system. Check your support provider's web site or knowledgebase for more information about obtaining the latest disk firmware.
- Syslog Message
%d disks have downrev firmware. They will be updated automatically using background disk firmware update if the correct firmware files are in place.
- Parameters
driveCount (INT): Number of disks that need to have updated firmware.
disk.fw.downrevWarning
- Severity
ERROR
- Description
- Corrective Action
Download and install the latest disk firmware file. Check your support provider's web site or knowledgebase for more information about obtaining the latest disk firmware.
- Syslog Message
%d disks have downrev firmware that you need to update.
- Parameters
