nvmem.voltage events
Creating your file...
nvmem.voltage.high
- Severity
EMERGENCY
- Description
This message occurs when the NVMEM supply voltage is high and the system is at a high risk of data loss if power fails. The system will shut down.
- Corrective Action
Correct any environmental or battery problems. If the problem persists, replace the controller module.
- Syslog Message
The NVMEM supply voltage is high and the system is at a high risk of data loss if power fails. The system will shut down to prevent data loss.
- Parameters
(None).
nvmem.voltage.high.warn
- Severity
INFORMATIONAL
- Description
This message occurs when the NVMEM supply voltage is above normal.
- Corrective Action
(None).
- Syslog Message
The NVMEM supply voltage is above normal.
- Parameters
(None).
nvmem.voltage.low
- Severity
ALERT
- Description
This message occurs when the NVMEM supply voltage is low and the system is at a high risk of data loss if power fails.
- Corrective Action
First, correct any environmental or battery problems. If the problem continues, replace the controller module.
- Syslog Message
The NVMEM supply voltage is low and the system is at a high risk of data loss if power fails.
- Parameters
(None).
nvmem.voltage.low.warn
- Severity
INFORMATIONAL
- Description
This message occurs when the NVMEM supply voltage is below normal.
- Corrective Action
(None).
- Syslog Message
The NVMEM supply voltage is below normal.
- Parameters
(None).
nvmem.voltage.normal
- Severity
INFORMATIONAL
- Description
This message occurs when the NVMEM supply voltage is normal.
- Corrective Action
(None).
- Syslog Message
The NVMEM supply voltage is normal.
- Parameters
(None).
