nvmem.voltage events
nvmem.voltage.high
Severity
EMERGENCY
This message occurs when the NVMEM supply voltage is high and the system is at a high risk of data loss if power fails. The system will shut down.
Corrective Action
Correct any environmental or battery problems. If the problem persists, replace the controller module.
Syslog Message
The NVMEM supply voltage is high and the system is at a high risk of data loss if power fails. The system will shut down to prevent data loss.
(None).
nvmem.voltage.high.warn
Severity
INFORMATIONAL
This message occurs when the NVMEM supply voltage is above normal.
Corrective Action
(None).
Syslog Message
The NVMEM supply voltage is above normal.
(None).
nvmem.voltage.low
Severity
ALERT
This message occurs when the NVMEM supply voltage is low and the system is at a high risk of data loss if power fails.
Corrective Action
First, correct any environmental or battery problems. If the problem continues, replace the controller module.
Syslog Message
The NVMEM supply voltage is low and the system is at a high risk of data loss if power fails.
(None).
nvmem.voltage.low.warn
Severity
INFORMATIONAL
This message occurs when the NVMEM supply voltage is below normal.
Corrective Action
(None).
Syslog Message
The NVMEM supply voltage is below normal.
(None).
nvmem.voltage.normal
Severity
INFORMATIONAL
This message occurs when the NVMEM supply voltage is normal.
Corrective Action
(None).
Syslog Message
The NVMEM supply voltage is normal.
(None).
