ONTAP EMS reference
acp.shelf events
acp.shelf EMS events occur when ONTAP encounters issues associated with the Alternate Control Path (ACP) Processor completing disk shelf power operations.
acp.shelf.power.cycle.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor fails to complete a power cycle of the disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power cycle request issued to %s failed because %s.
shelf_id (STRING): In-band ID or Shelf Serial Number of the module.
status (STRING): Reason for failure.
acp.shelf.power.cycle.success
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor successfully completes a power cycle of the disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power cycle request issued to %s is successful.
acp.shelf.power.off
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor receives a command to power off the disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power off request issued to %s
shelf_id (STRING): In-band ID of the module or Shelf Serial Number.
acp.shelf.power.off.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Controller Path Administrator fails in its attempt to power-off the SAS disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power off request sent to %s failed with status %s
shelf_id (STRING): In-band ID of the module.
status (STRING): Reason for the power-off failure.
acp.shelf.power.off.success
Severity
INFORMATIONAL
This message occurs when a 'shelf power off' command sent to the Alternate Controller Path (ACP) Processor succeeds.
Corrective Action
(None).
Syslog Message
Disk shelf power off command sent to %s was successful
acp.shelf.power.on
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor receives a command to power on a disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power up request issued to %s
acp.shelf.power.on.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Controller Path Administrator fails in its attempt to power on the SAS disk shelf.
Corrective Action
(None).
Syslog Message
Disk shelf power on request sent to %s failed with status %s
status (STRING): Reason for the 'power-on' failure.
acp.shelf.power.on.success
Severity
INFORMATIONAL
This message occurs when a 'shelf power on' command sent to the Alternate Controller Path (ACP) Processor succeeds.
Corrective Action
(None).
Syslog Message
Disk shelf power on command sent to %s was successful
