wackiron.near events
Creating your file...
wackiron.near.hour.limit
- Severity
ERROR
- Description
This message occurs when the number of hours since wafliron was last run on the specified volume is approaching its limit. If the limit is passed and the bootarg 'wackiron_enforce_panic' is true, the system will panic on the next boot.
- Corrective Action
Run wafliron on the affected volume. From the boot menu, run 'wafliron'. From the dblade CLI, run 'aggr wafliron start [aggr-name]'.
- Syslog Message
%s: Hours since wafliron was last run is approaching its limit. Hours remaining: %d.
- Parameters
volname (STRING): Name of the aggregate.
remaining (INT): Number of hours remaining.
wackiron.near.kernel.limit
- Severity
ERROR
- Description
This message occurs when the number of different Data ONTAP® kernel versions used since wafliron was last run on the specified volume is approaching its limit. If the limit is passed and the bootarg 'wackiron_enforce_panic' is true, the system will panic on the next boot.
- Corrective Action
- Syslog Message
%s: Number of different Data ONTAP kernel versions used since wafliron was last run is approaching its limit. Data ONTAP kernel version changes remaining: %d.
- Parameters
remaining (INT): Number of Data ONTAP kernel version changes remaining.
