ONTAP EMS reference
vol.reserve events
vol.reserve EMS events occur when WAFL® grows the reserve of a flexible volume that is running dangerously low on blocks for writing.
vol.reserve.grew
Severity
ERROR
This message occurs when WAFL® grows the reserve of a flexible volume that was running dangerously low on blocks for writing.
Corrective Action
Create space by increasing the volume size, deleting data, or changing the provisioning from thick to thin. To increase a volume's size, use the "volume size" command. To change provisioning in a volume reserved files can be unreserved by using the "volume file reservation" command.
Syslog Message
WAFL grew reserve of volume %s%s%s because the volume was running low on blocks.
name (STRING): Name of the volume.
app (STRING): Application UUID.
vserver_uuid (STRING): Name of the associated Vserver's UUID.
