vol.reserve events
Creating your file...
Your file is ready
vol.reserve.grew
- Severity
ERROR
- Description
This message occurs when WAFL® grows the reserve of a flexible volume that was running dangerously low on blocks for writing.
- Corrective Action
Create space by increasing the volume size, deleting data, or changing the provisioning from thick to thin. To increase a volume's size, use the "volume size" command. To change provisioning in a volume reserved files can be unreserved by using the "volume file reservation" command.
- Syslog Message
WAFL grew reserve of volume %s%s%s because the volume was running low on blocks.
- Parameters
name (STRING): Name of the volume.
app (STRING): Application UUID.
vserver_uuid (STRING): Name of the associated Vserver's UUID.
