sm.vfiler events
SM.vfiler.config.move.warn
- Severity
NOTICE
- Description
This message occurs when movement of the SnapMirror® status configuration from 'from' vFiler to 'to' vFiler fails. The SnapMirror or SnapVault® status might show the wrong status entries because the status entries are not copied.
- Corrective Action
(None).
- Syslog Message
Movement of SnapMirror status configuration failed while moving volumes between vFiler %s to vFiler %s. SnapMirror or SnapVault status might show the wrong status entries.
- Parameters
from_vfiler (STRING): vFiler(tm) from which resources are being moved.
to_vfiler (STRING): vFiler to which resources are being moved.
