ONTAP EMS reference
mgmtgwd.filereplication events
mgmtgwd.filereplication EMS events occur when ONTAP encounters issues associated with the file replication service.
mgmtgwd.filereplication.failverify
Severity
ERROR
This message occurs when the startup scan of the file replication publishing root directory fails to verify packages. This might be due to file corruption or a mixed-version issue.
Corrective Action
Contact NetApp technical support.
Syslog Message
The startup scan of the file replication publishing directory failed to verify one or more packages.
(None).
mgmtgwd.filereplication.forbidden
Severity
ERROR
This message occurs when the file replication service receives a request on an unsecure network interface.
Corrective Action
Use the "network interface show" command to verify that the source IP address of the request is from an internal, authorized source. This could be a security breach attempt. File replication never attempts to communicate over nonclustered interfaces.
Syslog Message
The file replication service denied an incoming request that came from '%s' through the virtual interface address '%s'.
client_ip (STRING): IP address of the client.
server_ip (STRING): IP address of the server interface.
mgmtgwd.filereplication.nopubroot
Severity
ERROR
This message occurs when the file replication service cannot find or initialize the publishing root directory.
Corrective Action
Syslog Message
The publishing root directory at '%s' could not be initialized. Error: '%s'.
dir (STRING): Location of the publishing root directory.
reason (STRING): Reason the directory cannot be used.
mgmtgwd.filereplication.noserver
Severity
ERROR
This message occurs when the file replication module cannot initialize the local server process.
Corrective Action
Ensure that the local replication network port is not in use ("network port show" and "network port broadcast-domain show") and that system resources are not limited.
Syslog Message
The file replication service could not initialize its server process. Error: '%s'.
description (STRING): Reason for the failure.
mgmtgwd.filereplication.nostart
Severity
ERROR
This message occurs when the file replication service cannot be started.
Corrective Action
Syslog Message
The file replication service could not be started.
(None).
