mgmtgwd.filereplication events
mgmtgwd.filereplication.failverify
- Severity
ERROR
 - Description
This message occurs when the startup scan of the file replication publishing root directory fails to verify packages. This might be due to file corruption or a mixed-version issue.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
The startup scan of the file replication publishing directory failed to verify one or more packages.
 - Parameters
(None).
mgmtgwd.filereplication.forbidden
- Severity
ERROR
 - Description
This message occurs when the file replication service receives a request on an unsecure network interface.
 - Corrective Action
Use the "network interface show" command to verify that the source IP address of the request is from an internal, authorized source. This could be a security breach attempt. File replication never attempts to communicate over nonclustered interfaces.
 - Syslog Message
The file replication service denied an incoming request that came from '%s' through the virtual interface address '%s'.
 - Parameters
client_ip (STRING): IP address of the client.
server_ip (STRING): IP address of the server interface.
mgmtgwd.filereplication.nopubroot
- Severity
ERROR
 - Description
This message occurs when the file replication service cannot find or initialize the publishing root directory.
 - Corrective Action
 - Syslog Message
The publishing root directory at '%s' could not be initialized. Error: '%s'.
 - Parameters
dir (STRING): Location of the publishing root directory.
reason (STRING): Reason the directory cannot be used.
mgmtgwd.filereplication.noserver
- Severity
ERROR
 - Description
This message occurs when the file replication module cannot initialize the local server process.
 - Corrective Action
Ensure that the local replication network port is not in use ("network port show" and "network port broadcast-domain show") and that system resources are not limited.
 - Syslog Message
The file replication service could not initialize its server process. Error: '%s'.
 - Parameters
description (STRING): Reason for the failure.
mgmtgwd.filereplication.nostart
- Severity
ERROR
 - Description
This message occurs when the file replication service cannot be started.
 - Corrective Action
 - Syslog Message
The file replication service could not be started.
 - Parameters
(None).
