The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
monitor.fru events
Creating your file...
Your file is ready
monitor.fru.info.readable
- Severity
INFORMATIONAL
- Description
This message occurs when the inventory information about a field-replaceable unit (FRU) that was previously unreadable becomes readable.
- Corrective Action
(None).
- Syslog Message
The inventory information of FRU %s is readable.
- Parameters
fru_name (STRING): FRU name.
monitor.fru.info.unreadable
- Severity
ERROR
- Description
This message occurs when the inventory information of a field-replaceable unit (FRU) is not readable.
- Corrective Action
See the system hardware guide for the replacement of the FRU. At the earliest convenient time, remove and reinsert the FRU to reseat it, and then resume normal system operation. If the error persists, replace the FRU according to the hardware guide directions.
- Syslog Message
The inventory information of FRU %s is not readable.
- Parameters
